Ir para o conteúdo principal
Acer Aspire E5-571-58CG Power Jack Replacement
O que você precisa
  1. Acer Aspire E5-571-58CG Power Jack Replacement, Battery: passo 1, imagem 1 %32 Acer Aspire E5-571-58CG Power Jack Replacement, Battery: passo 1, imagem 2 %32
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG Power Jack Replacement: passo 2, imagem 1 %32 Acer Aspire E5-571-58CG Power Jack Replacement: passo 2, imagem 2 %32 Acer Aspire E5-571-58CG Power Jack Replacement: passo 2, imagem 3 %32
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: passo 3, imagem 1 %32 Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: passo 3, imagem 2 %32 Acer Aspire E5-571-58CG Power Jack Replacement, Power Jack: passo 3, imagem 3 %32
    • Remove the top panel of the laptop with the plastic opening tool.
  4. Acer Aspire E5-571-58CG Power Jack Replacement: passo 4, imagem 1 %32 Acer Aspire E5-571-58CG Power Jack Replacement: passo 4, imagem 2 %32
    • Remove the plastic safeguard from the CD drive slot.
  5. Acer Aspire E5-571-58CG Power Jack Replacement: passo 5, imagem 1 %32 Acer Aspire E5-571-58CG Power Jack Replacement: passo 5, imagem 2 %32 Acer Aspire E5-571-58CG Power Jack Replacement: passo 5, imagem 3 %32
    • Remove the marked screws with the JIS #00 screwdriver.
  6. Acer Aspire E5-571-58CG Power Jack Replacement: passo 6, imagem 1 %32 Acer Aspire E5-571-58CG Power Jack Replacement: passo 6, imagem 2 %32
    • Disconnect the opposite end of the power jack from the motherboard by carefully pulling the wire.
  7. Acer Aspire E5-571-58CG Power Jack Replacement: passo 7, imagem 1 %32 Acer Aspire E5-571-58CG Power Jack Replacement: passo 7, imagem 2 %32
    • Lift the bottom right side of the screen to move the metal plate covering the power jack.
  8. Acer Aspire E5-571-58CG Power Jack Replacement: passo 8, imagem 1 %32 Acer Aspire E5-571-58CG Power Jack Replacement: passo 8, imagem 2 %32
    • Carefully lift the power jack out of the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Aliana Johnson
Membro desde: 10/24/18
145 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S7-G7, Valliere Fall 2018 Membro de UMass Dartmouth, Team S7-G7, Valliere Fall 2018
UMASSD-VALLIERE-F18S7G7
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 1,258
