Ir para o conteúdo principal
Acer Aspire E5-571-58CG CPU Fan Replacement
O que você precisa
  1. Acer Aspire E5-571-58CG CPU Fan Replacement, Battery: passo 1, imagem 1 %32 Acer Aspire E5-571-58CG CPU Fan Replacement, Battery: passo 1, imagem 2 %32
    • Make sure the laptop is powered off.
    • Flip the laptop over and locate the battery release switch.
    • Insert the pointed end of the spudger into the battery release switch.
    • Push the battery release switch to the right.
  2. Acer Aspire E5-571-58CG CPU Fan Replacement: passo 2, imagem 1 %32 Acer Aspire E5-571-58CG CPU Fan Replacement: passo 2, imagem 2 %32 Acer Aspire E5-571-58CG CPU Fan Replacement: passo 2, imagem 3 %32
    • While the battery release switch is pushed to the right, carefully slide the battery out of its socket.
  3. Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: passo 3, imagem 1 %32 Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: passo 3, imagem 2 %32 Acer Aspire E5-571-58CG CPU Fan Replacement, CPU Fan: passo 3, imagem 3 %32
    • Remove the top panel of the laptop with the plastic opening tool.
  4. Acer Aspire E5-571-58CG CPU Fan Replacement: passo 4, imagem 1 %32 Acer Aspire E5-571-58CG CPU Fan Replacement: passo 4, imagem 2 %32
    • Use a JIS #000 screw bit to remove the marked screw.
  5. Acer Aspire E5-571-58CG CPU Fan Replacement: passo 5, imagem 1 %32 Acer Aspire E5-571-58CG CPU Fan Replacement: passo 5, imagem 2 %32
    • Carefully pull the marked green chip out of the motherboard.
  6. Acer Aspire E5-571-58CG CPU Fan Replacement: passo 6, imagem 1 %32 Acer Aspire E5-571-58CG CPU Fan Replacement: passo 6, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Use tweezers to unplug the wire connecting the fan to the motherboard.
  7. Acer Aspire E5-571-58CG CPU Fan Replacement: passo 7, imagem 1 %32 Acer Aspire E5-571-58CG CPU Fan Replacement: passo 7, imagem 2 %32 Acer Aspire E5-571-58CG CPU Fan Replacement: passo 7, imagem 3 %32
    • Use a JIS #00 screw bit to remove the marked screws around the CPU fan.
    • Carefully remove the CPU fan.
Conclusão
Brendan Cuthill
Membro desde: 10/29/18
121 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team S7-G7, Valliere Fall 2018 Membro de UMass Dartmouth, Team S7-G7, Valliere Fall 2018
UMASSD-VALLIERE-F18S7G7
Membros da 5
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 7
Últimos 30 dias: 14
Duração total: 308
