Introdução
If the battery life is shortened, you may need to replace the laptop's battery. This guide will help you through this process.
O que você precisa
Flip the laptop over and locate the battery release switch.
Insert the pointed end of the spudger into the battery release switch.
Push the battery release switch to the right.
Uma outra pessoa concluiu este guia.
