Ir para o conteúdo principal
Acer Aspire E5-571 Keyboard Replacement
O que você precisa
  1. Acer Aspire E5-571 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Make sure the laptop is shut down.
    • Flip the laptop upside down. Rotate it so the battery faces you.
  2. Acer Aspire E5-571 Keyboard Replacement: passo 2, imagem 1 %32
    • Place the pointed end of a spudger into the battery lock. Slide the battery lock to the left using the spudger. A "click" sound will accompany the release of the battery.
  3. Acer Aspire E5-571 Keyboard Replacement: passo 3, imagem 1 %32
    • Pull the battery towards you to remove it from the laptop.
  4. Acer Aspire E5-571 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32
    • Remove all eighteen 8 mm screws with a Phillips #0 screwdriver.
  5. Acer Aspire E5-571 Keyboard Replacement: passo 5, imagem 1 %32 Acer Aspire E5-571 Keyboard Replacement: passo 5, imagem 2 %32 Acer Aspire E5-571 Keyboard Replacement: passo 5, imagem 3 %32
    • Carefully pry apart the clips holding the keyboard in place by moving a metal spudger along the seam.
    • Be careful not to break the plastic clips. Do not remove the keyboard until told to do so.
  6. Acer Aspire E5-571 Keyboard Replacement: passo 6, imagem 1 %32 Acer Aspire E5-571 Keyboard Replacement: passo 6, imagem 2 %32
    • Carefully flip up the white hinge. Then, detach the three ZIF ribbons connected to the motherboard.
    • Remove the panel with the keyboard and the touchpad.
Conclusão
9 outras pessoas executaram este guia.
daniel sawyer
Membro desde: 08/23/15
2.566 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team 4-2, Meier Fall 2015 Membro de USF Tampa, Team 4-2, Meier Fall 2015
USFT-MEIER-F15S4G2
Membros da 3
Autoria de 5 guias
4 comentários
keyboard cable is a b$%*h
shrs - Responder
can you explain how to remove the keyboard and attach the new one to the whole top
christhesoccerkid - Responder
keyboard cable is indeed a b$%*h, but you will get there with the patience of a zen master
here's a video that shows the extra steps of remo9ving and replacing keyboard: https://www.youtube.com/watch?v=DpawPQrq...
tom - Responder
I'm only 13 and it was easy to get to the dvd-rw drive and unjam it, little hands made the keyboard cable a breeze.
tha B-BOY - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 9
Últimos 30 dias: 39
Duração total: 12,196
