Ir para o conteúdo principal
Acer Aspire E5-511p-C6US RAM Replacement
O que você precisa
  1. Acer Aspire E5-511p-C6US RAM Replacement, Battery: passo 1, imagem 1 %32 Acer Aspire E5-511p-C6US RAM Replacement, Battery: passo 1, imagem 2 %32 Acer Aspire E5-511p-C6US RAM Replacement, Battery: passo 1, imagem 3 %32
    • On the back of the laptop, there is a sliding lock. Push the slider and the battery will unlock
  2. Acer Aspire E5-511p-C6US RAM Replacement: passo 2, imagem 1 %32
    • Pull battery to remove.
  3. Acer Aspire E5-511p-C6US RAM Replacement, Optical Drive: passo 3, imagem 1 %32 Acer Aspire E5-511p-C6US RAM Replacement, Optical Drive: passo 3, imagem 2 %32
    • Remove the 1 screw just above the battery with a Phillips #1 screwdriver.
  4. Acer Aspire E5-511p-C6US RAM Replacement: passo 4, imagem 1 %32 Acer Aspire E5-511p-C6US RAM Replacement: passo 4, imagem 2 %32
    • Pull the Optical Drive out
  5. Acer Aspire E5-511p-C6US RAM Replacement, Keyboard: passo 5, imagem 1 %32
    • Remove the 17 Phillips #1 screws remaining on the back side of the laptop
  6. Acer Aspire E5-511p-C6US RAM Replacement: passo 6, imagem 1 %32 Acer Aspire E5-511p-C6US RAM Replacement: passo 6, imagem 2 %32 Acer Aspire E5-511p-C6US RAM Replacement: passo 6, imagem 3 %32
    • Flip over the laptop, Using the spudger separate the body of the keyboard from the base of the laptop.
  7. Acer Aspire E5-511p-C6US RAM Replacement: passo 7, imagem 1 %32 Acer Aspire E5-511p-C6US RAM Replacement: passo 7, imagem 2 %32
    • Carefully lift the keyboard and disconnect the 3 ribbon style connectors from the computers boards.
  8. Acer Aspire E5-511p-C6US RAM Replacement, Fan: passo 8, imagem 1 %32 Acer Aspire E5-511p-C6US RAM Replacement, Fan: passo 8, imagem 2 %32
    • Disconnect the cord from the fan
  9. Acer Aspire E5-511p-C6US RAM Replacement: passo 9, imagem 1 %32
    • Remove the 2 #1 Phillips screws
  10. Acer Aspire E5-511p-C6US RAM Replacement: passo 10, imagem 1 %32
    • now the fan can be pulled from the laptop
  11. Acer Aspire E5-511p-C6US RAM Replacement, RAM: passo 11, imagem 1 %32
    • Disconnect the 2 plugs remaining on the computer
  12. Acer Aspire E5-511p-C6US RAM Replacement: passo 12, imagem 1 %32
    • Remove the last 2 #1 Philips screws from the body
  13. Acer Aspire E5-511p-C6US RAM Replacement: passo 13, imagem 1 %32
    • Remove the 2 #1 Phillips screws, then slide the metal cover back and away
  14. Acer Aspire E5-511p-C6US RAM Replacement: passo 14, imagem 1 %32
    • Remove the board from the laptop body, flip over for access to the ram
  15. Acer Aspire E5-511p-C6US RAM Replacement: passo 15, imagem 1 %32 Acer Aspire E5-511p-C6US RAM Replacement: passo 15, imagem 2 %32
    • Press down on the spring clips on either side of the ram, It will unlock and can be removed
Conclusão
Aaron
Membro desde: 03/19/18
562 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 652
