Introdução
The battery is one of the most important parts of a laptop. Without a battery, the laptop cannot function while unplugged. Follow these steps to replace your battery.
O que você precisa
Carefully place the closed computer on a flat surface, with it oriented screen down.
Now you need to use the Phillips #0 Screwdriver to remove all 17 of the M2.5X8 mm screws. Use the red circles on the diagram to help you locate these screws.
