Ir para o conteúdo principal
Acer Aspire E3-111-C0WA Wireless Card Replacement
O que você precisa
  1. Acer Aspire E3-111-C0WA Wireless Card Replacement, Battery: passo 1, imagem 1 %32 Acer Aspire E3-111-C0WA Wireless Card Replacement, Battery: passo 1, imagem 2 %32
    • Remove the 13 indicated screws (6.2 mm) using a Phillips #1 screwdriver.
  2. Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 2, imagem 1 %32 Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 2, imagem 2 %32 Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 2, imagem 3 %32
    • Insert your plastic opening tool between the bottom case and the rest of the laptop.
    • Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
    • Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
    • Lift the bottom off the laptop.
  3. Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 3, imagem 1 %32 Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Anti-Static Wrist Strap
    $7.95
    Comprar
    • Make sure you have properly grounded yourself to avoid potentially damaging any internal components by wearing the anti-static wrist strap and attaching the clip end to metal.
    • Press and hold the battery discharge button on the motherboard for 5 seconds to drain the battery.
  4. Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 4, imagem 1 %32 Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 4, imagem 2 %32 Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 4, imagem 3 %32
    • Dislodge the battery's connector to the motherboard by using the plastic opening tool as a lever on the two small plastic tabs that stick out on either side of the connector.
  5. Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 5, imagem 1 %32 Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 5, imagem 2 %32
    • Unscrew the two 6.2 mm Phillips #1 head screws on either side of the battery as indicated.
  6. Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 6, imagem 1 %32 Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 6, imagem 2 %32
    • Lift the battery up and off the rest of the laptop.
  7. Acer Aspire E3-111-C0WA Wireless Card Replacement, Wireless Card: passo 7, imagem 1 %32 Acer Aspire E3-111-C0WA Wireless Card Replacement, Wireless Card: passo 7, imagem 2 %32
    • Remove the two antenna cables from the wireless card. These should snap lightly out of place when lifted upwards.
  8. Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 8, imagem 1 %32 Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 8, imagem 2 %32 Acer Aspire E3-111-C0WA Wireless Card Replacement: passo 8, imagem 3 %32
    • Remove the 6.2mm #1 Phillips head screw attaching the wireless card to the case.
    • Pull the wireless card horizontally away from the motherboard to remove it from the connector.
Conclusão
Uma outra pessoa concluiu este guia.
Jonathan Chandler
Membro desde: 10/17/17
503 Reputação
Autoria de 4 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 7
Duração total: 322
