Introdução
Should you wish to replace or upgrade the memory in your laptop, this guide will show you how to access and remove your old RAM.
O que você precisa
Insert your plastic opening tool between the bottom case and the rest of the laptop.
Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
Lift the bottom off the laptop.
Remove the two antenna cables from the wireless card. These should snap lightly out of place when lifted upwards.
Holding the laptop in place, slide the hard drive horizontally out from the SATA connector.
Lightly pry upwards on the black plastic tab to release the touchpad cable, then gently pull the cable from the connector.
Um comentário
Thank you for this very well done step by step guide! I updated the RAM in this computer with no issues because of your procedure. FYI - I am a fellow Gaucho graduate way back from the Class of 1981.
