Introdução
After determining that your laptop's battery needs to be replaced, follow this replacement guide to remove your old battery and put in a new one.
O que você precisa
Insert your plastic opening tool between the bottom case and the rest of the laptop.
Using the plastic opening tool as a lever, apply downward pressure on the tool to lift the bottom up.
Make your way around the case with the tool, every so often applying downward pressure to lift the bottom up.
Lift the bottom off the laptop.
