Ir para o conteúdo principal
Acer Aspire E1-572-6829 Battery Replacement
O que você precisa
  1. Acer Aspire E1-572-6829 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Before beginning, make sure the laptop is turned off and the charger is unplugged.
    • Flip the laptop over so that you are facing the back panel.
    • Locate the battery lock switch below the battery.
  2. Acer Aspire E1-572-6829 Battery Replacement: passo 2, imagem 1 %32 Acer Aspire E1-572-6829 Battery Replacement: passo 2, imagem 2 %32 Acer Aspire E1-572-6829 Battery Replacement: passo 2, imagem 3 %32
    • Slide the battery lock switch to the open position using your finger or a plastic spudger.
    • While holding this switch open, use your other hand to slide the battery out from the back of the laptop.
    • Your battery is removed. You can now let go of the lock switch.
    • To reinsert the battery, make sure that it's tabs are lined up with the laptop and that it is facing in the right direction. Then slide it straight back in without using the lock switch.
Conclusão
Uma outra pessoa concluiu este guia.
Lauren Donlan
Membro desde: 03/13/23
112 Reputação
Autoria de 1 guia
Equipe
UMass Dartmouth, Team 2-2, Petersen Spring 2023 Membro de UMass Dartmouth, Team 2-2, Petersen Spring 2023
UMASSD-PETERSEN-S23S2G2
Membros da 3
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Duração total: 232
