Ir para o conteúdo principal
Acer Aspire E1-531-2438 Wifi Card Replacement
O que você precisa
  1. Acer Aspire E1-531-2438 Wifi Card Replacement, Battery: passo 1, imagem 1 %32 Acer Aspire E1-531-2438 Wifi Card Replacement, Battery: passo 1, imagem 2 %32
    • Unplug and power down the device before removing the battery.
    • Turn the device over so the back side is facing up.
    • Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
    • Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
  2. Acer Aspire E1-531-2438 Wifi Card Replacement: passo 2, imagem 1 %32
    • Tilt the side of the battery closest to the orange latch upward.
    • Lift the battery up and out of the device.
  3. Acer Aspire E1-531-2438 Wifi Card Replacement, WiFi Card: passo 3, imagem 1 %32 Acer Aspire E1-531-2438 Wifi Card Replacement, WiFi Card: passo 3, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
  4. Acer Aspire E1-531-2438 Wifi Card Replacement: passo 4, imagem 1 %32 Acer Aspire E1-531-2438 Wifi Card Replacement: passo 4, imagem 2 %32 Acer Aspire E1-531-2438 Wifi Card Replacement: passo 4, imagem 3 %32
    • Using the indentation, pry open the access panel with your fingers or a spudger.
    • Remove the access panel to expose the hard drive, WiFi card, and RAM modules.
  5. Acer Aspire E1-531-2438 Wifi Card Replacement: passo 5, imagem 1 %32
    • Using a spudger, disconnect the two antenna cables connectors on the WiFi card.
  6. Acer Aspire E1-531-2438 Wifi Card Replacement: passo 6, imagem 1 %32 Acer Aspire E1-531-2438 Wifi Card Replacement: passo 6, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the 3mm screw holding the WiFi card in place.
    • The card will then lift up after the screw is removed.
    • Remove the card by pulling out in the direction that the card is now orientated.
Conclusão
Jakob Rinkus
Membro desde: 03/21/19
965 Reputação
Autoria de 7 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 963
