Introdução
Bad connection to WiFi, connection dropping out, or no connection at all? This guide will explain how to remove the WiFi card on an Acer Aspire E1-531-2438.
O que você precisa
Turn the device over so the back side is facing up.
Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
