Ir para o conteúdo principal
Acer Aspire E1-531-2438 Hard Drive Replacement
O que você precisa
  1. Acer Aspire E1-531-2438 Hard Drive Replacement, Battery: passo 1, imagem 1 %32 Acer Aspire E1-531-2438 Hard Drive Replacement, Battery: passo 1, imagem 2 %32
    • Unplug and power down the device before removing the battery.
    • Turn the device over so the back side is facing up.
    • Using a spudger, slide the orange latch to the right. This will release the battery, which should pop up from the device.
    • Use two hands tilt the side of the battery closest to the orange latch upward as shown in the images.
  2. Acer Aspire E1-531-2438 Hard Drive Replacement: passo 2, imagem 1 %32
    • Tilt the side of the battery closest to the orange latch upward.
    • Lift the battery up and out of the device.
  3. Acer Aspire E1-531-2438 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32 Acer Aspire E1-531-2438 Hard Drive Replacement, Hard Drive: passo 3, imagem 2 %32
    • Using a Phillips #0 screwdriver, remove the two 9mm screws on the access panel.
  4. Acer Aspire E1-531-2438 Hard Drive Replacement: passo 4, imagem 1 %32 Acer Aspire E1-531-2438 Hard Drive Replacement: passo 4, imagem 2 %32 Acer Aspire E1-531-2438 Hard Drive Replacement: passo 4, imagem 3 %32
    • Using the indentation, pry open the access panel with your fingers or a spudger.
    • Remove the access panel to expose the hard drive, WiFi chip, and RAM modules.
  5. Acer Aspire E1-531-2438 Hard Drive Replacement: passo 5, imagem 1 %32 Acer Aspire E1-531-2438 Hard Drive Replacement: passo 5, imagem 2 %32 Acer Aspire E1-531-2438 Hard Drive Replacement: passo 5, imagem 3 %32
    • Grip the plastic tab on the hard drive, then pull to the left to unplug the drive from its socket.
    • Once free from the socket, lift the hard drive up and out of the device.
Conclusão
Uma outra pessoa concluiu este guia.
Jakob Rinkus
Membro desde: 03/21/19
965 Reputação
Autoria de 7 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 50
Ao todo: 2,276
