Ir para o conteúdo principal
Acer Aspire E1-531 Wi-Fi Wireless Card Replacement
O que você precisa
  1. Acer Aspire E1-531 Wi-Fi Wireless Card Replacement, Wi-Fi Wireless Card: passo 1, imagem 1 %32 Acer Aspire E1-531 Wi-Fi Wireless Card Replacement, Wi-Fi Wireless Card: passo 1, imagem 2 %32 Acer Aspire E1-531 Wi-Fi Wireless Card Replacement, Wi-Fi Wireless Card: passo 1, imagem 3 %32
    • Flip your computer over and examine the back. Look for a bright orange switch, as shown in the pictures to the left.
    • Take the spudger and press against the orange switch and tart pushing the button to the left until it releases the battery.
  2. Acer Aspire E1-531 Wi-Fi Wireless Card Replacement: passo 2, imagem 1 %32
    • Take out the battery completely.
  3. Acer Aspire E1-531 Wi-Fi Wireless Card Replacement: passo 3, imagem 1 %32 Acer Aspire E1-531 Wi-Fi Wireless Card Replacement: passo 3, imagem 2 %32
    • Use the appropriate screw driver and remove screws to take off the back.
    • Take the opening tool and begin to pry open the back of the bottom cover like in Picture 2.
  4. Acer Aspire E1-531 Wi-Fi Wireless Card Replacement: passo 4, imagem 1 %32 Acer Aspire E1-531 Wi-Fi Wireless Card Replacement: passo 4, imagem 2 %32
    • Once the back is off, the inside of the computer should be revealed, like the picture shown.
    • Identify the Wi-Fi wireless card.
  5. Acer Aspire E1-531 Wi-Fi Wireless Card Replacement: passo 5, imagem 1 %32
    • Grab the Wi-Fi card to "wiggle" it out of place.
    • Wiggle it out of place until the card is completely detached from the computer.
  6. Acer Aspire E1-531 Wi-Fi Wireless Card Replacement: passo 6, imagem 1 %32
    • Detach the connector from the computer to completely detach the Wi-Fi wireless card.
    • Once detached, take the new wireless card and follow these instructions in the reverse order.
Conclusão
3 outras pessoas executaram este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 20
Duração total: 3,324
