Ir para o conteúdo principal
Acer Aspire E1-510P-4637 Touch Screen Display Replacement
O que você precisa
  1. Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Battery: passo 1, imagem 1 %32
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: passo 2, imagem 1 %32
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Touch Screen Display: passo 3, imagem 1 %32 Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Touch Screen Display: passo 3, imagem 2 %32 Acer Aspire E1-510P-4637 Touch Screen Display Replacement, Touch Screen Display: passo 3, imagem 3 %32
    • Remove the plastic screw covers located near the laptop's hinge using a metal spudger.
    • Remove the two M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
  4. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: passo 4, imagem 1 %32 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: passo 4, imagem 2 %32 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: passo 4, imagem 3 %32
    • Flip the laptop over and open it up so the screen is facing up and the top of the screen is facing you.
    • Use a plastic opening tool to separate the the touchscreen from the back cover.
    • Carefully work your way around the frame and gently pry. Be careful not to brake the frame or damage the screen.
  5. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: passo 5, imagem 1 %32 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: passo 5, imagem 2 %32 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: passo 5, imagem 3 %32
    • Disconnect the display cable by first taking off the tape using a metal spudger and then pulling on the black tab.
  6. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: passo 6, imagem 1 %32 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: passo 6, imagem 2 %32
    • Take off the yellow tape connecting the display to the border.
  7. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: passo 7, imagem 1 %32 Acer Aspire E1-510P-4637 Touch Screen Display Replacement: passo 7, imagem 2 %32
    • Pull back the adhesive using the metal spudger.
    • Pry out the camera by lifting the adhesive with the metal spudger. Then, remove the camera by lifting it up by one side.
  8. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: passo 8, imagem 1 %32
    • Remove the two brackets holding the displays by unscrewing both M1 .6x3 screws with a PH0 Phillips screwdriver.
  9. Acer Aspire E1-510P-4637 Touch Screen Display Replacement: passo 9, imagem 1 %32
    • Release the display from the border using your hands.
Conclusão
Caleb lindsay
Membro desde: 04/11/16
778 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 34-15, Maness Spring 2016 Membro de Cal Poly, Team 34-15, Maness Spring 2016
CPSU-MANESS-S16S34G15
4 Membros
Autoria de 6 guias
Um comentário
the touchscreen its glue together with the LCD?
Chris Foliaki - Responder
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Ao todo: 1,233
