Ir para o conteúdo principal
Acer Aspire E1-510P-4637 Keyboard Replacement
O que você precisa
  1. Acer Aspire E1-510P-4637 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • To release the battery, depress the battery release with a nylon spudger. Hold the latch down and slide it over.
  2. Acer Aspire E1-510P-4637 Keyboard Replacement: passo 2, imagem 1 %32
    • Firmly grab hold of the battery and slide it out of the laptop.
  3. Acer Aspire E1-510P-4637 Keyboard Replacement, Hard Drive: passo 3, imagem 1 %32
    • Remove the M2.5x8 screw with a PH1 screwdriver.
  4. Acer Aspire E1-510P-4637 Keyboard Replacement: passo 4, imagem 1 %32
    • Use the plastic opening tool to pop off the small back cover.
  5. Acer Aspire E1-510P-4637 Keyboard Replacement: passo 5, imagem 1 %32
    • Use a PH0 Phillips screwdriver to remove the screw securing the hard drive.
  6. Acer Aspire E1-510P-4637 Keyboard Replacement: passo 6, imagem 1 %32 Acer Aspire E1-510P-4637 Keyboard Replacement: passo 6, imagem 2 %32
    • Use a nylon spudger to slightly pry up the hard drive near the screw holes.
  7. Acer Aspire E1-510P-4637 Keyboard Replacement: passo 7, imagem 1 %32 Acer Aspire E1-510P-4637 Keyboard Replacement: passo 7, imagem 2 %32 Acer Aspire E1-510P-4637 Keyboard Replacement: passo 7, imagem 3 %32
    • Grab hold of the plastic tab and pull the hard drive away from the connectors. This will release the hard drive.
    • The hard drive connector is fragile. Handle with care.
  8. Acer Aspire E1-510P-4637 Keyboard Replacement, Keyboard: passo 8, imagem 1 %32
    • Remove the fourteen M2.5x8 screws highlighted in the picture with a PH0 Phillips screwdriver.
  9. Acer Aspire E1-510P-4637 Keyboard Replacement: passo 9, imagem 1 %32
    • Slide out the disk drive tray.
  10. Acer Aspire E1-510P-4637 Keyboard Replacement: passo 10, imagem 1 %32
    • Use the plastic opening tool to gently pry open the laptop.
  11. Acer Aspire E1-510P-4637 Keyboard Replacement: passo 11, imagem 1 %32 Acer Aspire E1-510P-4637 Keyboard Replacement: passo 11, imagem 2 %32 Acer Aspire E1-510P-4637 Keyboard Replacement: passo 11, imagem 3 %32
    • Rotate the back cover up a little to reveal the cables connected to the motherboard.
    • Unplug the cables by sliding them out of their receptacle.
    • The connectors are very small and fragile. Handle with care.
  12. Acer Aspire E1-510P-4637 Keyboard Replacement: passo 12, imagem 1 %32
    • Remove the four center panel M1.6x3 screws with a PH0 Phillips screwdriver.
    • Remove the two M2x3 screws with a PH0 Phillips screwdriver.
  13. Acer Aspire E1-510P-4637 Keyboard Replacement: passo 13, imagem 1 %32 Acer Aspire E1-510P-4637 Keyboard Replacement: passo 13, imagem 2 %32 Acer Aspire E1-510P-4637 Keyboard Replacement: passo 13, imagem 3 %32
    • Use the plastic opening tool to slide the metal part out to release it from the retaining tabs.
  14. Acer Aspire E1-510P-4637 Keyboard Replacement: passo 14, imagem 1 %32 Acer Aspire E1-510P-4637 Keyboard Replacement: passo 14, imagem 2 %32
    • Peel off the foil adhesive stuck to the keyboard.
  15. Acer Aspire E1-510P-4637 Keyboard Replacement: passo 15, imagem 1 %32
    • Remove the keyboard.
Conclusão
Caleb lindsay
Membro desde: 04/11/16
778 Reputação
Autoria de 6 guias
Equipe
Cal Poly, Team 34-15, Maness Spring 2016 Membro de Cal Poly, Team 34-15, Maness Spring 2016
CPSU-MANESS-S16S34G15
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 1,187
