Introdução
This guide walks you through the proper steps to disconnect and remove the battery from the Laptop.
Ferramentas
Peças
Nenhum componente especificado.
Unscrew the thirteen 6.2mm Phillips #1 screws located on the bottom of the device.
Press and hold the small black button located on the motherboard just above the battery for five seconds.
6 outras pessoas concluíram este guia.
4 comentários
Can I remove the battery and use only the ac adapter to power it? Will it work and not cause damage to the unit?
when you take the battery out it works ok and when you put the battery the orange light when take out the battery its fine could it be the battery or board connector
when battery is out it works fine when connect out and orange and blue light come on then no display remove battery every returns to normal
