Ir para o conteúdo principal
Acer Aspire A315-58 LCD Screen Replacement
O que você precisa
  1. Acer Aspire A315-58 LCD Screen Replacement, LCD Screen: passo 1, imagem 1 %32
    • Take the screws out and open the lowercase
  2. Acer Aspire A315-58 LCD Screen Replacement, Battery, LCD cable and Wifi cable removal: passo 2, imagem 1 %32 Acer Aspire A315-58 LCD Screen Replacement, Battery, LCD cable and Wifi cable removal: passo 2, imagem 2 %32
    • First, remember to disconnect the battery by sliding the latch towards the battery from the motherboard.
    • Then disconnect the LCD cable (left corner) and the Wifi Cable.
    • Take out four screws at the left and right corners that connect the upper case and LCD part
  3. Acer Aspire A315-58 LCD Screen Replacement, Screen replacement: passo 3, imagem 1 %32 Acer Aspire A315-58 LCD Screen Replacement, Screen replacement: passo 3, imagem 2 %32 Acer Aspire A315-58 LCD Screen Replacement, Screen replacement: passo 3, imagem 3 %32
    • Take out the screws and heat up the both edge of the screen where the adhesive tape at.
    • Replace the new tapes shown in the picture on both sides and reassemble the LCD back to the Cover.
Conclusão
Uma outra pessoa concluiu este guia.
Gongmin Zhou
Membro desde: 06/21/23
105 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 51
Ao todo: 791
