Introdução
This guide will show you how to remove the secondary hard drive. You will need to do this if the drive has become faulty and you have a new one, or if you want to use it in another device.
O que você precisa
Make sure the device is unplugged and completely powered down.
Turn the device over.
While looking at the bottom of the device upside down from the front, the secondary hard drive is in the near, left corner.
Using a Phillips #1 screwdriver, remove the two 7mm screws on the right side of the cover.
Uma outra pessoa concluiu este guia.
