Introdução
This guide will show you ho to remove the optical disk drive, usually a CD or DVD reader and/or writer. You might need to do this if it is malfunctioning and needs to be replace, or if you are upgrading to a better one.
Peças
Não são necessárias peças.
  1. Make sure the device is unplugged and completely powered down. Turn the device over.
    • Make sure the device is unplugged and completely powered down.
    • Turn the device over.
  2. The lock switch can slide either towards or away from the battery.  If it is pushed towards the battery, the release switch is locked and the battery can not be released. Slide the switch away from the battery.
    • The lock switch can slide either towards or away from the battery. If it is pushed towards the battery, the release switch is locked and the battery can not be released.
    • Slide the switch away from the battery.
  3. Free shipping on all orders over US$100,00 or containing a Pro Tech Toolkit!
    Visite Nossa Loja
  4. The battery release switch is just to the inside of the battery and slides parallel to it. Push the switch to the side. It is not just an open or close switch, it actually pops the battery up so you will feel some resistance. When inserting a battery back into the device, you do not need to touch this switch. Just press the battery firmly down, you will see and hear this switch catch.
    • The battery release switch is just to the inside of the battery and slides parallel to it.
    • Push the switch to the side. It is not just an open or close switch, it actually pops the battery up so you will feel some resistance.
    • When inserting a battery back into the device, you do not need to touch this switch. Just press the battery firmly down, you will see and hear this switch catch.
  5. Pull the battery up and out. Use a plastic opening tool if necessary. Pull the battery up and out. Use a plastic opening tool if necessary. Pull the battery up and out. Use a plastic opening tool if necessary.
    • Pull the battery up and out. Use a plastic opening tool if necessary.
  6. Using a Phillips #1 screwdriver, remove the 7mm screw holding the drive. Using a Phillips #1 screwdriver, remove the 7mm screw holding the drive.
    • Using a Phillips #1 screwdriver, remove the 7mm screw holding the drive.
  7. Slide the drive out of the bay. Slide the drive out of the bay.
    • Slide the drive out of the bay.
Conclusão
Patrick McKenna
611 reputação
5 Guides authored
Equipe
Visualizar Estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Todo: 30
