Introdução
This guide will show you ho to remove the optical disk drive, usually a CD or DVD reader and/or writer. You might need to do this if it is malfunctioning and needs to be replace, or if you are upgrading to a better one.
O que você precisa
Make sure the device is unplugged and completely powered down.
Turn the device over.
Using a Phillips #1 screwdriver, remove the 7mm screw holding the drive.
Quase terminado!
Conclusão
