Ir para o conteúdo principal
Acer Aspire 5750-6667 Optical Drive Replacement
O que você precisa
  1. Acer Aspire 5750-6667 Optical Drive Replacement, Battery: passo 1, imagem 1 %32 Acer Aspire 5750-6667 Optical Drive Replacement, Battery: passo 1, imagem 2 %32
    • Unplug the charging cable from the laptop and the wall. Failure to disconnect the charging cable could result in electric shock.
    • Turn the laptop over.
    • Locate the orange switch next to the battery.
  2. Acer Aspire 5750-6667 Optical Drive Replacement: passo 2, imagem 1 %32 Acer Aspire 5750-6667 Optical Drive Replacement: passo 2, imagem 2 %32 Acer Aspire 5750-6667 Optical Drive Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using a small tool such as tweezers or a pen, slide the orange switch completely to the left to unlock the battery.
    • While holding the orange switch in place, lift the battery by the lip and pull it away from the laptop.
  3. Acer Aspire 5750-6667 Optical Drive Replacement, Optical Drive: passo 3, imagem 1 %32 Acer Aspire 5750-6667 Optical Drive Replacement, Optical Drive: passo 3, imagem 2 %32
    • Locate the black screw just above the battery.
    • Remove the black screw holding the optical drive in place by using a Phillips #0 screwdriver.
  4. Acer Aspire 5750-6667 Optical Drive Replacement: passo 4, imagem 1 %32 Acer Aspire 5750-6667 Optical Drive Replacement: passo 4, imagem 2 %32
    • Pull the optical drive free from the laptop.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 16
Ao todo: 1,298
