Introdução
RAM in a laptop is often upgraded in order to make increase storage capacity and performance. RAM is easily replaced by removing 2 screws and pulling on two clamps that surround the RAM.
O que você precisa
Flip the laptop over and locate the bottom access panel. It is opposite the battery.
Locate the 2 screws that hold the panel in place and unscrew them using a Phillips PH0 screwdriver.
Lift the clear plastic flap and locate the pair of metal brackets that are holding the top RAM in place.
Using your thumbs, push the brackets away from the RAM . It should pop up when released.
You can now gently pull the top RAM out of the laptop.
Locate the second pair of metal clasps holding the bottom RAM in place.
Using your thumbs, push the brackets away from the RAM . The RAM board should pop up when released.
You can now gently pull the top RAM out of the laptop. Repeat for any other RAM boards that may be in the device.
