Ir para o conteúdo principal
Acer Aspire 5750-6667 Memory Replacement
O que você precisa
  1. Acer Aspire 5750-6667 Memory Replacement, Battery: passo 1, imagem 1 %32 Acer Aspire 5750-6667 Memory Replacement, Battery: passo 1, imagem 2 %32
    • Unplug the charging cable from the laptop and the wall. Failure to disconnect the charging cable could result in electric shock.
    • Turn the laptop over.
    • Locate the orange switch next to the battery.
  2. Acer Aspire 5750-6667 Memory Replacement: passo 2, imagem 1 %32 Acer Aspire 5750-6667 Memory Replacement: passo 2, imagem 2 %32 Acer Aspire 5750-6667 Memory Replacement: passo 2, imagem 3 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Using a small tool such as tweezers or a pen, slide the orange switch completely to the left to unlock the battery.
    • While holding the orange switch in place, lift the battery by the lip and pull it away from the laptop.
  3. Acer Aspire 5750-6667 Memory Replacement, Bottom Access Panel: passo 3, imagem 1 %32 Acer Aspire 5750-6667 Memory Replacement, Bottom Access Panel: passo 3, imagem 2 %32 Acer Aspire 5750-6667 Memory Replacement, Bottom Access Panel: passo 3, imagem 3 %32
    • Flip the laptop over and locate the bottom access panel. It is opposite the battery.
    • Locate the 2 screws that hold the panel in place and unscrew them using a Phillips PH0 screwdriver.
  4. Acer Aspire 5750-6667 Memory Replacement: passo 4, imagem 1 %32 Acer Aspire 5750-6667 Memory Replacement: passo 4, imagem 2 %32 Acer Aspire 5750-6667 Memory Replacement: passo 4, imagem 3 %32
    • Use the blue plastic opening tool to lift the panel away from the laptop.
  5. Acer Aspire 5750-6667 Memory Replacement, RAM: passo 5, imagem 1 %32 Acer Aspire 5750-6667 Memory Replacement, RAM: passo 5, imagem 2 %32 Acer Aspire 5750-6667 Memory Replacement, RAM: passo 5, imagem 3 %32
    • Lift the clear plastic flap and locate the pair of metal brackets that are holding the top RAM in place.
    • Using your thumbs, push the brackets away from the RAM . It should pop up when released.
    • You can now gently pull the top RAM out of the laptop.
  6. Acer Aspire 5750-6667 Memory Replacement: passo 6, imagem 1 %32 Acer Aspire 5750-6667 Memory Replacement: passo 6, imagem 2 %32 Acer Aspire 5750-6667 Memory Replacement: passo 6, imagem 3 %32
    • Locate the second pair of metal clasps holding the bottom RAM in place.
    • Using your thumbs, push the brackets away from the RAM . The RAM board should pop up when released.
    • You can now gently pull the top RAM out of the laptop. Repeat for any other RAM boards that may be in the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 10
Duração total: 861
