Ir para o conteúdo principal
Acer Aspire 5749 Fan/HeatSink Replacement
O que você precisa
  1. Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: passo 1, imagem 1 %32 Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: passo 1, imagem 2 %32 Acer Aspire 5749 Fan/HeatSink Replacement, Fan/HeatSink: passo 1, imagem 3 %32
    • Retrieve all Screw's from the bottom of the laptop and organize them into 2 different sets.
    • When removing the back cover gently press on audio connections on the back right of the laptop.
  2. Acer Aspire 5749 Fan/HeatSink Replacement: passo 2, imagem 1 %32 Acer Aspire 5749 Fan/HeatSink Replacement: passo 2, imagem 2 %32 Acer Aspire 5749 Fan/HeatSink Replacement: passo 2, imagem 3 %32
    • Carefully release and unplug every wire that connects to the fan.
  3. Acer Aspire 5749 Fan/HeatSink Replacement: passo 3, imagem 1 %32 Acer Aspire 5749 Fan/HeatSink Replacement: passo 3, imagem 2 %32 Acer Aspire 5749 Fan/HeatSink Replacement: passo 3, imagem 3 %32
    • Release the screw that connects the fan to the base of the laptop. Carefully remove your fan and heat sink.
    • Apply heat paste to the center before replacing the fan and heat sink. Then reinsert the screw and plugs.
Conclusão
8 outras pessoas executaram este guia.
JeanChristophe
Membro desde: 11/19/10
523 Reputação
Autoria de 3 guias
5 comentários
May need to expand the "apply heat paste to center" section. Need to remove old paste first, etc. etc. A good bird's eye view intro, though
polishtext4 - Responder
Tanks you…
I'll look forward for adding this info.
JeanChristophe -
Seemed like I was going to rip the motherboard up where the usb ports are by the audio connector, why isn't the %#*@ thing screwed down? Lol If I push down by the audio connector like you mention and pull it up from the other side will ot be fine, felt and looked like I might snap the board.
Clayton Boyle - Responder
Good job, did have to Emphasis about releasing the audio connectors
Thaine Ferris - Responder
I didn't know how to explain better…
Some trick of trade?
JeanChristophe -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 12
Duração total: 7,822
