Ir para o conteúdo principal
Acer Aspire 5742 Keyboard Replacement
O que você precisa
  1. Acer Aspire 5742 Keyboard Replacement, Battery: passo 1, imagem 1 %32 Acer Aspire 5742 Keyboard Replacement, Battery: passo 1, imagem 2 %32 Acer Aspire 5742 Keyboard Replacement, Battery: passo 1, imagem 3 %32
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 Keyboard Replacement, Keyboard: passo 2, imagem 1 %32 Acer Aspire 5742 Keyboard Replacement, Keyboard: passo 2, imagem 2 %32 Acer Aspire 5742 Keyboard Replacement, Keyboard: passo 2, imagem 3 %32
    • Unfold the laptop so that you are looking at the keyboard.
    • At the top right of the keyboard you will notice two clips above the 'Del' and 'End' keys.
    • Using your spudger, press these clips in to unlock the keyboard from the laptop
    • Be careful not to press too forcefully on these clips with the spudger as they may break
    • Slide the spudger along the top of the keyboard until the keyboard is able to easily be lifted up out of the laptop
    • Do NOT attempt to fully remove the keyboard as there is still a cable on its backside connected to the computer that can be damaged
  3. Acer Aspire 5742 Keyboard Replacement: passo 3, imagem 1 %32 Acer Aspire 5742 Keyboard Replacement: passo 3, imagem 2 %32 Acer Aspire 5742 Keyboard Replacement: passo 3, imagem 3 %32
    • Now that the keyboard is outside of the laptop, you will see a ribbon cable coming from the back of the keyboard connected to the laptop.
    • To detach this cable you must use the pointed edge of the spudger to press down on the locking mechanisms on each side.
    • Do not use too much pressure when disconnecting the ZIF connector.
    • After unlocking both sides of the ZIF connector remove the keyboard for replacement.
Conclusão
6 outras pessoas executaram este guia.
Bill Murray
Membro desde: 10/24/16
581 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-6, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 2-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G6
Membros da 3
Autoria de 8 guias
2 comentários
Ik zie het vergrendelingsmechanisme bij stap drie niet. Wat ik ook naar beneden druk hij de kabel wil niet loslaten. Moet de klem misschien omhoog?
Hans Hendriks - Responder
Sehen Sie sich Recognizing & Disconnecting Cable Connectors an. Möglicherweise gibt es eine Verriegelungsstange, die Sie anheben (Schritt 1) oder eine Stange, die Sie vorsichtig auf die andere Seite des Steckers drücken müssen (Schritt 7). Sobald Sie es ausgearbeitet haben, ist es einfach. (Beschuldigen Sie Google Translate, wenn dies keinen Sinn ergibt!)
Philip Le Riche - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 34
Duração total: 6,526
