Ir para o conteúdo principal
Acer Aspire 5742 Hard Drive Removal
O que você precisa
  1. Acer Aspire 5742 Hard Drive Removal, Battery: passo 1, imagem 1 %32 Acer Aspire 5742 Hard Drive Removal, Battery: passo 1, imagem 2 %32 Acer Aspire 5742 Hard Drive Removal, Battery: passo 1, imagem 3 %32
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 Hard Drive Removal, Cover Panel: passo 2, imagem 1 %32 Acer Aspire 5742 Hard Drive Removal, Cover Panel: passo 2, imagem 2 %32 Acer Aspire 5742 Hard Drive Removal, Cover Panel: passo 2, imagem 3 %32
    • Turn the notebook around to face you.
    • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
  3. Acer Aspire 5742 Hard Drive Removal: passo 3, imagem 1 %32 Acer Aspire 5742 Hard Drive Removal: passo 3, imagem 2 %32 Acer Aspire 5742 Hard Drive Removal: passo 3, imagem 3 %32
    • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
    • Do not apply too much force, or you may break the clips.
    • Remove the panel and set it aside.
  4. Acer Aspire 5742 Hard Drive Removal, Hard drive: passo 4, imagem 1 %32 Acer Aspire 5742 Hard Drive Removal, Hard drive: passo 4, imagem 2 %32 Acer Aspire 5742 Hard Drive Removal, Hard drive: passo 4, imagem 3 %32
    • Unscrew the Phillips #00 screw which retains the hard drive in place.
    • Gently slide the hard drive to the left in order to disengage the SATA connectors.
    • It may be quite stiff, in which case you can ease the hard drive out of the SATA connectors by inserting a spudger between the hard drive and the connector block.
    • Lift the drive out of the notebook.
Conclusão
16 outras pessoas executaram este guia.
Skylar MacDonald
Membro desde: 12/04/11
1.964 Reputação
Autoria de 5 guias
4 comentários
Great guide except for the missing screw sizes. Does anybody know the screw sizes?
patrickscott - Responder
I have this laptop with a bad HDD, it was a Toshiba 640 GB , 5400 RPM drive.
I like to know if this laptop supports 7200 RPM drives
Also, does this laptop support an SSD drive ?
Shahzaan - Responder
Yes, any 2.5in SATA HDD or SSD can be fitted in place of any other.
Philip Le Riche -
I love this guide! It's the best! Thank You!
Mark Wiens - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 51
Duração total: 45,463
