Ir para o conteúdo principal
Fix Your Stuff
Right to Repair
Parts & Tools
Introdução
Removal of the hard drive is easy, but just be careful not to knock, jerk or drop it in the process as it's a delicate electromechanical device.
Peças
Nenhum componente especificado.
  1. Move the battery catch to the "unlocked" position. Pull back the second spring-loaded battery catch until the battery pops up. Remove the battery.
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Turn the notebook around to face you. There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws. There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
    • Turn the notebook around to face you.
    • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
  3. Use a spudger to release the panel from the plastic retaining clips keeping it in place. Do not apply too much force, or you may break the clips. Remove the panel and set it aside.
    • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
    • Do not apply too much force, or you may break the clips.
    • Remove the panel and set it aside.
  4. Unscrew the Phillips #00 screw which retains the hard drive in place. Gently slide the hard drive to the left in order to disengage the SATA connectors. It may be quite stiff, in which case you can ease the hard drive out of the SATA connectors by inserting a spudger between the hard drive and the connector block.
    • Unscrew the Phillips #00 screw which retains the hard drive in place.
    • Gently slide the hard drive to the left in order to disengage the SATA connectors.
    • It may be quite stiff, in which case you can ease the hard drive out of the SATA connectors by inserting a spudger between the hard drive and the connector block.
    • Lift the drive out of the notebook.
Conclusão
15 outras pessoas concluíram este guia.
Skylar MacDonald
Membro desde: 04-12-2011
1.745 Reputation
5 Guias de autoria
Great guide except for the missing screw sizes. Does anybody know the screw sizes?
patrickscott - Responder
I have this laptop with a bad HDD, it was a Toshiba 640 GB , 5400 RPM drive.
I like to know if this laptop supports 7200 RPM drives
Also, does this laptop support an SSD drive ?
Shahzaan - Responder
Yes, any 2.5in SATA HDD or SSD can be fitted in place of any other.
Philip Le Riche -
Adicione um comentário
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 151
All Time: 37,523
