Ir para o conteúdo principal
Acer Aspire 5742 CMOS Battery Replacement
O que você precisa
  1. Acer Aspire 5742 CMOS Battery Replacement, Battery: passo 1, imagem 1 %32 Acer Aspire 5742 CMOS Battery Replacement, Battery: passo 1, imagem 2 %32 Acer Aspire 5742 CMOS Battery Replacement, Battery: passo 1, imagem 3 %32
    • Move the battery catch to the "unlocked" position.
    • Pull back the second spring-loaded battery catch until the battery pops up.
    • Remove the battery.
  2. Acer Aspire 5742 CMOS Battery Replacement, Cover Panel: passo 2, imagem 1 %32 Acer Aspire 5742 CMOS Battery Replacement, Cover Panel: passo 2, imagem 2 %32 Acer Aspire 5742 CMOS Battery Replacement, Cover Panel: passo 2, imagem 3 %32
    • Turn the notebook around to face you.
    • There are two Phillips #00 screws securing the cover panel to the rest of the notebook. Remove these screws.
  3. Acer Aspire 5742 CMOS Battery Replacement: passo 3, imagem 1 %32 Acer Aspire 5742 CMOS Battery Replacement: passo 3, imagem 2 %32 Acer Aspire 5742 CMOS Battery Replacement: passo 3, imagem 3 %32
    • Use a spudger to release the panel from the plastic retaining clips keeping it in place.
    • Do not apply too much force, or you may break the clips.
    • Remove the panel and set it aside.
  4. Acer Aspire 5742 CMOS Battery Replacement, CMOS Battery: passo 4, imagem 1 %32 Acer Aspire 5742 CMOS Battery Replacement, CMOS Battery: passo 4, imagem 2 %32
    • After removing the cover panel, you will see the hard drive, the RAM, and the CMOS battery.
    • The CMOS battery is the silver coin-like object in the center.
  5. Acer Aspire 5742 CMOS Battery Replacement: passo 5, imagem 1 %32 Acer Aspire 5742 CMOS Battery Replacement: passo 5, imagem 2 %32 Acer Aspire 5742 CMOS Battery Replacement: passo 5, imagem 3 %32
    • Press the tip of the spudger underneath the CMOS battery with very slight force.
    • Press down on the opposite side of the battery while prying the battery upward with the spudger.
    • After the battery is mostly lifted from the slot, you may pull out the battery with your fingers.
    Thanks! Too much info in all of the other tutorials I read. Battery replaced, working perfectly now.
    S Jacks - Responder
Conclusão
8 outras pessoas executaram este guia.
Bill Murray
Membro desde: 10/24/16
593 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 2-6, Isaacson Fall 2016 Membro de UMass Dartmouth, Team 2-6, Isaacson Fall 2016
UMASSD-ISAACSON-F16S2G6
3 Membros
Autoria de 8 guias
Um comentário
Comentar
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 17
Últimos 30 dias: 49
Ao todo: 14,885
