Ir para o conteúdo principal
Acer Aspire 5740-6378 Keyboard Replacement
O que você precisa
  1. Acer Aspire 5740-6378 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Slide the locking switch into the unlocked position to ready the battery for removal.
  2. Acer Aspire 5740-6378 Keyboard Replacement: passo 2, imagem 1 %32
    • Slide the release latch until the battery pops out.
  3. Acer Aspire 5740-6378 Keyboard Replacement: passo 3, imagem 1 %32
    • Remove the battery now that it's been unsecured.
  4. Acer Aspire 5740-6378 Keyboard Replacement, Keyboard: passo 4, imagem 1 %32
    • Open your device so you have ease of access to your keyboard.
  5. Acer Aspire 5740-6378 Keyboard Replacement: passo 5, imagem 1 %32 Acer Aspire 5740-6378 Keyboard Replacement: passo 5, imagem 2 %32 Acer Aspire 5740-6378 Keyboard Replacement: passo 5, imagem 3 %32
    • Pry off the mid cover using a spudger to reveal a cable attaching to the keyboard.
  6. Acer Aspire 5740-6378 Keyboard Replacement: passo 6, imagem 1 %32 Acer Aspire 5740-6378 Keyboard Replacement: passo 6, imagem 2 %32
    • Detach the cable by flipping the securing tab up and gently pulling the cable away from it.
  7. Acer Aspire 5740-6378 Keyboard Replacement: passo 7, imagem 1 %32 Acer Aspire 5740-6378 Keyboard Replacement: passo 7, imagem 2 %32
    • Pry off and flip over the keyboard using the spudger.
  8. Acer Aspire 5740-6378 Keyboard Replacement: passo 8, imagem 1 %32 Acer Aspire 5740-6378 Keyboard Replacement: passo 8, imagem 2 %32
    • Unlock the keyboard ribbon cable by flipping up the securing tab on the Zero Insertion Force (ZIF) connector.
    • Slide the ribbon cable free of the connector.
    • Remove the keyboard.
Conclusão
Ian Rodriguez
Membro desde: 03/20/19
734 Reputação
Autoria de 5 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 303
