Ir para o conteúdo principal
Acer Aspire 5740-5780 Battery Replacement
  1. Acer Aspire 5740-5780 Battery Replacement, Battery: passo 1, imagem 1 %32 Acer Aspire 5740-5780 Battery Replacement, Battery: passo 1, imagem 2 %32
    • Unlock the battery by flipping a switch near the release latch.
  2. Acer Aspire 5740-5780 Battery Replacement: passo 2, imagem 1 %32
    • Slide the release latch to the left to release the battery from the PC.
  3. Acer Aspire 5740-5780 Battery Replacement: passo 3, imagem 1 %32 Acer Aspire 5740-5780 Battery Replacement: passo 3, imagem 2 %32
    • Use your hands to pry the battery free of the computer.
Conclusão
Gian Farrell
Membro desde: 03/20/18
639 Reputação
Autoria de 6 guias
Equipe
UMass Dartmouth, Team S3-G6, Peak Spring 2018 Membro de UMass Dartmouth, Team S3-G6, Peak Spring 2018
UMASSD-PEAK-S18S3G6
Membros da 3
Autoria de 9 guias
Um comentário
Hi,
i have acer aspire 5740 which was running gine but suddenly went off and never turned back on. I tried 30 seconds holding power button procedure too but when i plugged the charger in the light flashes every 3 seconds . Could you please help me out to turn it back on because i got very important documents saved in.
regards
Umar - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 14
Duração total: 505
