Ir para o conteúdo principal
Acer Aspire 5740-5780 Back Cover Replacement
O que você precisa
  1. Cuidado: as etapas de 1 a 4 são provenientes de um guia marcado como em andamento.
    Acer Aspire 5740-5780 Back Cover Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: passo 1, imagem 1 %32 Acer Aspire 5740-5780 Back Cover Replacement, Prepare Acer Aspire 5740-5780 for Disassembly: passo 1, imagem 2 %32
    • Turn the laptop off and remove the power cord.
  2. Acer Aspire 5740-5780 Back Cover Replacement: passo 2, imagem 1 %32 Acer Aspire 5740-5780 Back Cover Replacement: passo 2, imagem 2 %32
    • Press in the SD Card or the SD Card Dummy if no SD Card is there. Remove card when it pops out.
  3. Acer Aspire 5740-5780 Back Cover Replacement: passo 3, imagem 1 %32
    • Flip the laptop over on its face, so that the back is showing.
  4. Acer Aspire 5740-5780 Back Cover Replacement: passo 4, imagem 1 %32
    • Put grounding strap on one of your wrists and attach the other end to a large metal object (recommended method).
    • If you don't have a grounding strap an alternative approach is to touch a metal object that is either large or connected to the earth. Then avoid doing things that would accumulate static electricity on your body.
    • Touching the internals of your device while you aren't grounded could destroy your laptop.
  5. Acer Aspire 5740-5780 Back Cover Replacement, Battery: passo 5, imagem 1 %32 Acer Aspire 5740-5780 Back Cover Replacement, Battery: passo 5, imagem 2 %32
    • Unlock the battery by flipping a switch near the release latch.
  6. Acer Aspire 5740-5780 Back Cover Replacement: passo 6, imagem 1 %32
    • Slide the release latch to the left to release the battery from the PC.
  7. Acer Aspire 5740-5780 Back Cover Replacement: passo 7, imagem 1 %32 Acer Aspire 5740-5780 Back Cover Replacement: passo 7, imagem 2 %32
    • Use your hands to pry the battery free of the computer.
  8. Acer Aspire 5740-5780 Back Cover Replacement, Back Cover: passo 8, imagem 1 %32 Acer Aspire 5740-5780 Back Cover Replacement, Back Cover: passo 8, imagem 2 %32
    • Unscrew the 2 captive screws and 3 M2.5 x L8 screws holding back cover in place.
  9. Acer Aspire 5740-5780 Back Cover Replacement: passo 9, imagem 1 %32 Acer Aspire 5740-5780 Back Cover Replacement: passo 9, imagem 2 %32
    • Use spudger to pry open the back panel.
    • Then lift panel off of the computer.
Conclusão
Dwyer Deighan
Membro desde: 03/25/18
358 Reputação
Autoria de 3 guias
Equipe
UMass Dartmouth, Team S3-G6, Peak Spring 2018 Membro de UMass Dartmouth, Team S3-G6, Peak Spring 2018
UMASSD-PEAK-S18S3G6
Membros da 3
Autoria de 9 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 20
Duração total: 720
