Introdução
To improve the quality of your Acer Aspire 5734z-4836 speaker. Few prerequisites are required of the front panel removal, but overall to replacement the speaker a couple additional screws needs to be remove and disconnecting the speaker wires.
O que você precisa
Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
Pinch the edges of the plastic covering above the keyboard, and pull away from the laptop until the covering pops off.
Begin with the laptop placed on its bottom and the empty keyboard space facing you.
Begin with the front panel flipped so the speaker is facing you.
Locate speaker on the lower left corner of the laptop.
Uma outra pessoa concluiu este guia.
