Ir para o conteúdo principal
Acer Aspire 5734z-4836 Screen Replacement
O que você precisa
  1. Acer Aspire 5734z-4836 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Before removing the battery, power off your laptop and disconnect the AC adapter.
    • Flip your laptop on its back so the battery is facing up and the hinges are facing away from you.
  2. Acer Aspire 5734z-4836 Screen Replacement: passo 2, imagem 1 %32
    • Slide the right latch down to unlock the battery.
  3. Acer Aspire 5734z-4836 Screen Replacement: passo 3, imagem 1 %32 Acer Aspire 5734z-4836 Screen Replacement: passo 3, imagem 2 %32
    • Slide and hold the left latch below the battery.
    • While holding this latch in place, pry the battery up from its bottom edge.
    • Lift the old battery out of its compartment.
  4. Acer Aspire 5734z-4836 Screen Replacement, Screen: passo 4, imagem 1 %32 Acer Aspire 5734z-4836 Screen Replacement, Screen: passo 4, imagem 2 %32
    • Remove rubber bumpers from each four corners to expose the hidden screws that hold the screen bezel in place.
  5. Acer Aspire 5734z-4836 Screen Replacement: passo 5, imagem 1 %32
    • Extract the hidden screws from each of the bezel's four corners, using a #00 Phillips screwdriver.
  6. Acer Aspire 5734z-4836 Screen Replacement: passo 6, imagem 1 %32
    • Pop the bezel loose along the edges with a plastic opening tool.
  7. Acer Aspire 5734z-4836 Screen Replacement: passo 7, imagem 1 %32 Acer Aspire 5734z-4836 Screen Replacement: passo 7, imagem 2 %32
    • Gently pry off the bezel by holding each edge of the bezel with a forefinger and applying pressure onto the screen with your thumbs.
    • Lift the bezel away completely.
  8. Acer Aspire 5734z-4836 Screen Replacement: passo 8, imagem 1 %32
    • Unscrew the middle screw on the green strip under the screen.
  9. Acer Aspire 5734z-4836 Screen Replacement: passo 9, imagem 1 %32 Acer Aspire 5734z-4836 Screen Replacement: passo 9, imagem 2 %32
    • Gently detach the red-and-white cable from the right end of the green strip under the screen.
  10. Acer Aspire 5734z-4836 Screen Replacement: passo 10, imagem 1 %32 Acer Aspire 5734z-4836 Screen Replacement: passo 10, imagem 2 %32
    • Locate six small screws, three on each side of the screen.
    • Remove all six screws with a #000 Phillips screwdriver.
  11. Acer Aspire 5734z-4836 Screen Replacement: passo 11, imagem 1 %32 Acer Aspire 5734z-4836 Screen Replacement: passo 11, imagem 2 %32
    • Disconnect wires from the webcam located above the screen.
  12. Acer Aspire 5734z-4836 Screen Replacement: passo 12, imagem 1 %32 Acer Aspire 5734z-4836 Screen Replacement: passo 12, imagem 2 %32 Acer Aspire 5734z-4836 Screen Replacement: passo 12, imagem 3 %32
    • Lift the screen up from the laptop and turn it around.
    • Gently peel back the tape located behind the screen.
  13. Acer Aspire 5734z-4836 Screen Replacement: passo 13, imagem 1 %32 Acer Aspire 5734z-4836 Screen Replacement: passo 13, imagem 2 %32
    • Pull the connector straight down to remove it.
    • You can now safely lift the screen out of the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Susan Cao
Membro desde: 09/12/16
121 Reputação
Autoria de 1 guia
Equipe
CSU Fullerton, Team 2-3, Bruce Fall 2016 Membro de CSU Fullerton, Team 2-3, Bruce Fall 2016
CSUF-BRUCE-F16S2G3
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 898
