Introdução
This repair guide will give you a step-by-step procedure on how to replace the screen on your Acer Aspire 5534-1146 device.
O que você precisa
Use the blue spudger to remove the 4 rubber supports from each corner of the screen.
After use a PH0 screw bit to remove the corresponding screws underneath.
Quase terminado!
Conclusão
