Ir para o conteúdo principal
Acer Aspire 5534-1146 Hard Drive Replacement
O que você precisa
  1. Acer Aspire 5534-1146 Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Locate where the hard drive is located on the back side of the laptop and unscrew the two .8cm Long screws.
  2. Acer Aspire 5534-1146 Hard Drive Replacement: passo 2, imagem 1 %32
    • Once you have have removed the back panel cover, find the hard drive’s location.
  3. Acer Aspire 5534-1146 Hard Drive Replacement: passo 3, imagem 1 %32
    • Find and locate the two screws that are 0.8cm long that are holding the hard drive in place to the back metal plate.
    • Carefully take a PH #0 screwdriver and remove the two screws.
  4. Acer Aspire 5534-1146 Hard Drive Replacement: passo 4, imagem 1 %32
    • Once you have unscrewed the two screws, carefully slide the hard drive the opposite direction of the screws that you just removed, slide the drive till it is free.
    • You are now ready to remove the hard drive from it’s compartment from the device.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 477
