Ir para o conteúdo principal
Acer Aspire 5517-1127 Keyboard Replacement
O que você precisa
  1. Acer Aspire 5517-1127 Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Orient the device with the keyboard facing towards you.
  2. Acer Aspire 5517-1127 Keyboard Replacement: passo 2, imagem 1 %32 Acer Aspire 5517-1127 Keyboard Replacement: passo 2, imagem 2 %32
    • Using a metal spudger, pry open the top panel of the device as shown.
  3. Acer Aspire 5517-1127 Keyboard Replacement: passo 3, imagem 1 %32 Acer Aspire 5517-1127 Keyboard Replacement: passo 3, imagem 2 %32 Acer Aspire 5517-1127 Keyboard Replacement: passo 3, imagem 3 %32
    • With the top panel remove, use the spudger to lift the keyboard out of the device as shown.
  4. Acer Aspire 5517-1127 Keyboard Replacement: passo 4, imagem 1 %32 Acer Aspire 5517-1127 Keyboard Replacement: passo 4, imagem 2 %32 Acer Aspire 5517-1127 Keyboard Replacement: passo 4, imagem 3 %32
    • The keyboard ribbon is shown after removing the keyboard. There are two tabs holding the ribbon in place as shown.
    • Using your fingers, pull the tabs towards you to release the ribbon from its casing.
Conclusão
Christopher Newkirk
Membro desde: 02/02/17
509 Reputação
Autoria de 4 guias
Equipe
USF Tampa, Team 17-1, Blackwell Spring 2017 Membro de USF Tampa, Team 17-1, Blackwell Spring 2017
USFT-BLACKWELL-S17S17G1
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 849
