Ir para o conteúdo principal
Acer Aspire 5349-2592 Screen Replacement
O que você precisa
  1. Acer Aspire 5349-2592 Screen Replacement, Screen: passo 1, imagem 1 %32
    • Open the laptop so that the screen is facing you.
  2. Acer Aspire 5349-2592 Screen Replacement: passo 2, imagem 1 %32
    • Pull of the plastic frame of the laptop screen.
  3. Acer Aspire 5349-2592 Screen Replacement: passo 3, imagem 1 %32
    • Unscrew the 1/4'' screws at each of the corners using a Phillips screwdriver
    • Pull off the screen from the device. If necessary, you may use a bezel provided by the iFixit tool kit.
    • Handle the Acer 5349-2592 LCD hinges with care as they are delicate.
Conclusão
Equipe
1Comentário do guia
your description is extremely lacking, the two screws near the hinges, and connections.
ComputerGuy Wilkes-Barre - Responder
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 24
Ao todo: 671
