Ir para o conteúdo principal
Acer Aspire 5349-2592 RAM Replacement
O que você precisa
  1. Acer Aspire 5349-2592 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over so that the back is facing you.
  2. Acer Aspire 5349-2592 RAM Replacement: passo 2, imagem 1 %32
    • Push the laptop battery release lock.
  3. Acer Aspire 5349-2592 RAM Replacement: passo 3, imagem 1 %32
    • Now that the Acer-Aspire 5349-2592 laptop battery is unlocked, press the battery release button down.
  4. Acer Aspire 5349-2592 RAM Replacement: passo 4, imagem 1 %32
    • Holding down the laptop battery release button, gently pull the battery away from the laptop.
  5. Acer Aspire 5349-2592 RAM Replacement, Back plate: passo 5, imagem 1 %32
    • Remove all of the screws located on the back of the laptop using your Phillips #0 screwdriver.
  6. Acer Aspire 5349-2592 RAM Replacement: passo 6, imagem 1 %32
    • Pry open the backplate using the iFixit opening tool and remove the backplate from the device.
  7. Acer Aspire 5349-2592 RAM Replacement, RAM: passo 7, imagem 1 %32 Acer Aspire 5349-2592 RAM Replacement, RAM: passo 7, imagem 2 %32
    • Push the clips securing the RAM outwards.
    • The RAM stick will pop up and is safe to remove from the device. Repeat the same process for additional RAM sticks.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 38
Ao todo: 2,151
