Ir para o conteúdo principal
Acer Aspire 5349-2592 Keyboard Replacement
O que você precisa
  1. Acer Aspire 5349-2592 Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over so that the back is facing you.
  2. Acer Aspire 5349-2592 Keyboard Replacement: passo 2, imagem 1 %32
    • Push the laptop battery release lock.
  3. Acer Aspire 5349-2592 Keyboard Replacement: passo 3, imagem 1 %32
    • Now that the Acer-Aspire 5349-2592 laptop battery is unlocked, press the battery release button down.
  4. Acer Aspire 5349-2592 Keyboard Replacement: passo 4, imagem 1 %32
    • Holding down the laptop battery release button, gently pull the battery away from the laptop.
  5. Acer Aspire 5349-2592 Keyboard Replacement, Keyboard: passo 5, imagem 1 %32 Acer Aspire 5349-2592 Keyboard Replacement, Keyboard: passo 5, imagem 2 %32
    • Open the laptop and locate the top edge of the keyboard.
    • Use a flathead screwdriver to gently pry the keyboard upward and lift it out of the laptop.
  6. Acer Aspire 5349-2592 Keyboard Replacement: passo 6, imagem 1 %32
    • Use a flathead screwdriver to gently lift the clamp upward and remove the cable.
  7. Acer Aspire 5349-2592 Keyboard Replacement: passo 7, imagem 1 %32
    • The keyboard is now disconnected and can be safely removed.
Conclusão
Uma outra pessoa concluiu este guia.
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 8
Últimos 30 dias: 18
Duração total: 1,000
