Ir para o conteúdo principal
Acer Aspire 5349-2592 Hard Drive Replacement
O que você precisa
  1. Acer Aspire 5349-2592 Hard Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over so that the back is facing you.
  2. Acer Aspire 5349-2592 Hard Drive Replacement: passo 2, imagem 1 %32
    • Push the laptop battery release lock.
  3. Acer Aspire 5349-2592 Hard Drive Replacement: passo 3, imagem 1 %32
    • Now that the Acer-Aspire 5349-2592 laptop battery is unlocked, press the battery release button down.
  4. Acer Aspire 5349-2592 Hard Drive Replacement: passo 4, imagem 1 %32
    • Holding down the laptop battery release button, gently pull the battery away from the laptop.
  5. Acer Aspire 5349-2592 Hard Drive Replacement, Back plate: passo 5, imagem 1 %32
    • Remove all of the screws located on the back of the laptop using your Phillips #0 screwdriver.
  6. Acer Aspire 5349-2592 Hard Drive Replacement: passo 6, imagem 1 %32
    • Pry open the backplate using the iFixit opening tool and remove the backplate from the device.
  7. Acer Aspire 5349-2592 Hard Drive Replacement, Hard Drive: passo 7, imagem 1 %32
    • Remove the the pin strip.
  8. Acer Aspire 5349-2592 Hard Drive Replacement: passo 8, imagem 1 %32
    • Remove the two screws from the caddy using the Phillips #0 screwdriver.
  9. Acer Aspire 5349-2592 Hard Drive Replacement: passo 9, imagem 1 %32
    • Slide out the caddy.
  10. Acer Aspire 5349-2592 Hard Drive Replacement: passo 10, imagem 1 %32 Acer Aspire 5349-2592 Hard Drive Replacement: passo 10, imagem 2 %32 Acer Aspire 5349-2592 Hard Drive Replacement: passo 10, imagem 3 %32
    • Slightly lift up the hard drive and pull it out from the device.
Conclusão
3 outras pessoas executaram este guia.
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 23
Ao todo: 1,898
