Ir para o conteúdo principal
Acer Aspire 5349-2592 Fan Replacement
O que você precisa
  1. Acer Aspire 5349-2592 Fan Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over so that the back is facing you.
  2. Acer Aspire 5349-2592 Fan Replacement: passo 2, imagem 1 %32
    • Push the laptop battery release lock.
  3. Acer Aspire 5349-2592 Fan Replacement: passo 3, imagem 1 %32
    • Now that the Acer-Aspire 5349-2592 laptop battery is unlocked, press the battery release button down.
  4. Acer Aspire 5349-2592 Fan Replacement: passo 4, imagem 1 %32
    • Holding down the laptop battery release button, gently pull the battery away from the laptop.
  5. Acer Aspire 5349-2592 Fan Replacement, Back plate: passo 5, imagem 1 %32
    • Remove all of the screws located on the back of the laptop using your Phillips #0 screwdriver.
  6. Acer Aspire 5349-2592 Fan Replacement: passo 6, imagem 1 %32
    • Pry open the backplate using the iFixit opening tool and remove the backplate from the device.
  7. Acer Aspire 5349-2592 Fan Replacement, CD / DVD Drive: passo 7, imagem 1 %32
    • Unscrew the single screw on the DVD drive with your Phillips #0 screwdriver.
  8. Acer Aspire 5349-2592 Fan Replacement: passo 8, imagem 1 %32
    • Gently lift the drive up and remove it from the pin.
Conclusão
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 288
