Ir para o conteúdo principal
Acer Aspire 5334-2581 Screen Replacement
O que você precisa
  1. Acer Aspire 5334-2581 Screen Replacement, Battery: passo 1, imagem 1 %32
    • Please make sure your device is unplugged . Turn it over slowly, and place it on a flat surface.
  2. Acer Aspire 5334-2581 Screen Replacement: passo 2, imagem 1 %32
    • This latch holds your battery in place, it should always be locked. Make sure to unlock this piece.
    • Do not break this latch, otherwise your battery will not hold in place.
  3. Acer Aspire 5334-2581 Screen Replacement: passo 3, imagem 1 %32
    • Locate the eject latch and push it so the battery can come out.
    • The battery will lift up once you have pushed the latch.
    • You DO NOT need to adjust the latch when replacing the new battery, because it just snaps in place.
  4. Acer Aspire 5334-2581 Screen Replacement: passo 4, imagem 1 %32
    • Lift the battery up, and it should just come right off. You should see the label with the part number.
  5. Acer Aspire 5334-2581 Screen Replacement, Screen: passo 5, imagem 1 %32
    • Remove the 4 rubber supports from the screen. Then remove the screws underneath.
  6. Acer Aspire 5334-2581 Screen Replacement: passo 6, imagem 1 %32
    • With a spudger, release the clips that hold the plastic frame to the back cover.
    • Be careful while handling the bottom, there are cable connections, and you don't want to damage them
  7. Acer Aspire 5334-2581 Screen Replacement: passo 7, imagem 1 %32
    • With caution disconnect the camera cable.
  8. Acer Aspire 5334-2581 Screen Replacement: passo 8, imagem 1 %32 Acer Aspire 5334-2581 Screen Replacement: passo 8, imagem 2 %32
    • Remove the 4 screws in the side of the LCD. Screen should be able to come of the frame
  9. Acer Aspire 5334-2581 Screen Replacement: passo 9, imagem 1 %32
    • Take the screen and flip on top of the keyboard.
    • Unplug the cable connected to the video card.
    • Don't use too much force, you don't want to damage this component.
  10. Acer Aspire 5334-2581 Screen Replacement: passo 10, imagem 1 %32 Acer Aspire 5334-2581 Screen Replacement: passo 10, imagem 2 %32
    • Remove the tape, and unplug the display cable.
    • Unstick the cable from the back of the LCD, and now the LCD is free to come off. You are ready to install a new one
    • Try not to damage this cable, otherwise replacing it would be so much pain.
Conclusão
gilson teixeira
Membro desde: 10/20/16
334 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-2, Catania Fall 2016 Membro de UMass Dartmouth, Team 1-2, Catania Fall 2016
UMASSD-CATANIA-F16S1G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 362
