Ir para o conteúdo principal
Acer Aspire 5334-2581 Battery Replacement
  1. Acer Aspire 5334-2581 Battery  Replacement, Battery: passo 1, imagem 1 %32
    • Please make sure your device is unplugged . Turn it over slowly, and place it on a flat surface.
  2. Acer Aspire 5334-2581 Battery  Replacement: passo 2, imagem 1 %32
    • This latch holds your battery in place, it should always be locked. Make sure to unlock this piece.
    • Do not break this latch, otherwise your battery will not hold in place.
  3. Acer Aspire 5334-2581 Battery  Replacement: passo 3, imagem 1 %32
    • Locate the eject latch and push it so the battery can come out.
    • The battery will lift up once you have pushed the latch.
    • You DO NOT need to adjust the latch when replacing the new battery, because it just snaps in place.
  4. Acer Aspire 5334-2581 Battery  Replacement: passo 4, imagem 1 %32
    • Lift the battery up, and it should just come right off. You should see the label with the part number.
Conclusão
gilson teixeira
Membro desde: 10/20/16
334 Reputação
Autoria de 5 guias
Equipe
UMass Dartmouth, Team 1-2, Catania Fall 2016 Membro de UMass Dartmouth, Team 1-2, Catania Fall 2016
UMASSD-CATANIA-F16S1G2
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Duração total: 289
