Ir para o conteúdo principal
Acer Aspire 5315 Assembly
O que você precisa
  1. Acer Aspire 5315 Assembly, Assembling the keyboard: passo 1, imagem 1 %32 Acer Aspire 5315 Assembly, Assembling the keyboard: passo 1, imagem 2 %32
    • To mount the keyboard, place it on the chassis and press until it clicks.
  2. Acer Aspire 5315 Assembly, Mounting the network card: passo 2, imagem 1 %32 Acer Aspire 5315 Assembly, Mounting the network card: passo 2, imagem 2 %32
    • To mount the network card, we have to put it diagonally if it can not be removed.
    • When it is already on, it is only necessary to adjust the screw.
    • To connect the two cables you must place them on their receptacles and press until they click in.
  3. Acer Aspire 5315 Assembly, Mounting the processor: passo 3, imagem 1 %32 Acer Aspire 5315 Assembly, Mounting the processor: passo 3, imagem 2 %32
    • To mount the processor, make sure you put it in straight, because if the pins bend, it will no longer work.
    • When it is in, you only have to adjust the screw to secure it.
  4. Acer Aspire 5315 Assembly, Mounting the heat sink: passo 4, imagem 1 %32 Acer Aspire 5315 Assembly, Mounting the heat sink: passo 4, imagem 2 %32
    • To mount the heatsink, we have to take good care of it, and if the processor could not be reheated, it would be wrong.
    • When it is well-seated replace the four screws to fix it.
    • Set the heatsink to the fan.
  5. Acer Aspire 5315 Assembly, Mounting the fan: passo 5, imagem 1 %32 Acer Aspire 5315 Assembly, Mounting the fan: passo 5, imagem 2 %32
    • When it is clean, return the four screws to it so that it does not come apart.
    • Then, place it in its place on the motherboard and secure it.
    • Do not forget to connect the cable.
  6. Acer Aspire 5315 Assembly, Inserting RAM: passo 6, imagem 1 %32 Acer Aspire 5315 Assembly, Inserting RAM: passo 6, imagem 2 %32
    • To place the RAM we have to be careful that it can also be broken as the network card.
    • We have to put it diagonally so it does not break.
Conclusão
Um agradecimento especial a esses tradutores:
es en
100%
Estes tradutores estão nos ajudando a consertar o mundo! Quer contribuir?
Comece a traduzir ›
Carlos Ibañez
Membro desde: 05/08/17
297 Reputação
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 19
Duração total: 543
