O que você precisa
Now, locate the two screws that hold the back cover panel onto the laptop.
After the panel has been loosened by the plastic opening tool, take your finger, place it in the gap, and remove the panel from the laptop.
Hello. Vous avez oublié de mentionner le démontage du disque dur (une vis) et le débranchement des fils des antennes wifi qui ne gênent pas pour vous lors du démontage de la carte mère.
Locate the tabs keeping the keyboard in place.
Using thin tweezers push the tabs in the keyboard in and pull up on the edge of the keyboard.
I’m attempting this but my keyboard doesn’t move and I can’t get it to pop up so I can remove it.
After you have removed all of the prerequisites its time to unscrew a few more screws. Flip your laptop over and first remove all the screw highlighted in red with the Phillips #00 screwdriver. These are 1/4" head diameter by 3/8" screw length screws.
Now remove the screws highlighted in orange with the Phillips #00 screwdriver. These are 5/32" head diameter by 5/32" screw length screws. Keep these separate from the other screws.
11 outras pessoas executaram este guia.
6 comentários
I loved it.. I'm goanna try it today to fix my Speakers and keyboards..
It is so nice to represent know-how here with steps. Thanks.
I loved it, very easy
Can the AV ports for the headphones also be fixed?
This is the left speaker. Where is the right speaker
Thank you soo much the steps are very much straight forward to follow. It was very helpful thank you.
