Ir para o conteúdo principal
Acer Aspire 5253 Optical Drive Replacement
O que você precisa
  1. Acer Aspire 5253 Optical Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over.
  2. Acer Aspire 5253 Optical Drive Replacement: passo 2, imagem 1 %32
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
  3. Acer Aspire 5253 Optical Drive Replacement: passo 3, imagem 1 %32
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
  4. Acer Aspire 5253 Optical Drive Replacement: passo 4, imagem 1 %32
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
  5. Acer Aspire 5253 Optical Drive Replacement: passo 5, imagem 1 %32
    • You have successfully removed the battery. Congratulations!
  6. Acer Aspire 5253 Optical Drive Replacement, Optical Drive: passo 6, imagem 1 %32
    • Turn the computer over and locate the screw that is in between the battery and cover panel as shown in the picture.
  7. Acer Aspire 5253 Optical Drive Replacement: passo 7, imagem 1 %32
    • Remove the screw with a Phillips #00 screw driver.
    • The screw is 3/8" in length and has a 1/4" head.
  8. Acer Aspire 5253 Optical Drive Replacement: passo 8, imagem 1 %32
    • Carefully pry the optical drive loose.
  9. Acer Aspire 5253 Optical Drive Replacement: passo 9, imagem 1 %32 Acer Aspire 5253 Optical Drive Replacement: passo 9, imagem 2 %32
    • Slowly remove the optical drive.
Conclusão
Cynthia Barajas
Membro desde: 04/08/14
2.258 Reputação
Autoria de 5 guias
Equipe
Cal Poly, Team 8-11, Regan Spring 2014 Membro de Cal Poly, Team 8-11, Regan Spring 2014
CPSU-REGAN-S14S8G11
4 Membros
Autoria de 15 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Ao todo: 6,782
