Ir para o conteúdo principal
Acer Aspire 5253 Battery Replacement
  1. Acer Aspire 5253 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Turn the laptop over.
  2. Acer Aspire 5253 Battery Replacement: passo 2, imagem 1 %32
    • "Unlock" your battery by moving the switch as shown so that an unlocked lock on a red background is shown.
  3. Acer Aspire 5253 Battery Replacement: passo 3, imagem 1 %32
    • Next move the other switch, while the unlocked symbol is still showing. The battery should pop up, and no longer be flush with the bottom of the laptop.
  4. Acer Aspire 5253 Battery Replacement: passo 4, imagem 1 %32
    • Now remove the battery by lifting it out of the laptop by the side closest to the switches.
  5. Acer Aspire 5253 Battery Replacement: passo 5, imagem 1 %32
    • You have successfully removed the battery. Congratulations!
Conclusão
To reassemble your device, return battery pack to designated area. Push down until you hear a click, then lock the battery back into place.
7 outras pessoas executaram este guia.
Joseph Gagliano
Membro desde: 04/08/14
573 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 8-11, Regan Spring 2014 Membro de Cal Poly, Team 8-11, Regan Spring 2014
CPSU-REGAN-S14S8G11
Membros da 4
Autoria de 15 guias
3 comentários
I have just bought aa new battery but wont hold the charge
Paul MGreor - Responder
Just bought a new battery and still draining faat
My computer acer aspire 21-531 has a blank screen with a blue two line enter current password when I try to enter the password it does not take it we had reset my computer and got this. Please help
Melinda harbison - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 17
Duração total: 11,926
