Ir para o conteúdo principal
Acer Aspire 5251-1513 RAM Replacement
O que você precisa
  1. Acer Aspire 5251-1513 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Turn over the laptop so the back is facing up.
  2. Acer Aspire 5251-1513 RAM Replacement: passo 2, imagem 1 %32 Acer Aspire 5251-1513 RAM Replacement: passo 2, imagem 2 %32
    • Next to the battery is a switch with a lock symbol on it.
    • Unlock the switch by sliding it to reveal a red unlock symbol.
  3. Acer Aspire 5251-1513 RAM Replacement: passo 3, imagem 1 %32 Acer Aspire 5251-1513 RAM Replacement: passo 3, imagem 2 %32
    • Pull the other switch completely while the red unlock symbol is still present. The battery pack should pop up a bit.
  4. Acer Aspire 5251-1513 RAM Replacement: passo 4, imagem 1 %32 Acer Aspire 5251-1513 RAM Replacement: passo 4, imagem 2 %32
    • Remove the battery pack via the indentation at the top of the battery in between the two switches.
  5. Acer Aspire 5251-1513 RAM Replacement, RAM: passo 5, imagem 1 %32
    • Unscrew the two 8.6 mm screws using a Phillips #0 screwdriver.
  6. Acer Aspire 5251-1513 RAM Replacement: passo 6, imagem 1 %32
    • Use a spudger or plastic opening tool to lift the panel up. Then remove the panel entirely with your hands.
  7. Acer Aspire 5251-1513 RAM Replacement: passo 7, imagem 1 %32 Acer Aspire 5251-1513 RAM Replacement: passo 7, imagem 2 %32 Acer Aspire 5251-1513 RAM Replacement: passo 7, imagem 3 %32
    • Find two metal pieces on either side of the RAM.
    • Pull the two tabs apart. The RAM will pop up when released.
  8. Acer Aspire 5251-1513 RAM Replacement: passo 8, imagem 1 %32
    • Gently pull the RAM out
    • Please be careful pulling out the RAM, only touch the edges.
    • Repeat step 8 & 9 for the second RAM piece if applicable.
Conclusão
Gicely Rodriguez
Membro desde: 02/14/19
1.029 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G6, Leahy Spring 2019 Membro de USF Tampa, Team S1-G6, Leahy Spring 2019
USFT-LEAHY-S19S1G6
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 16
Duração total: 741
