Ir para o conteúdo principal
Acer Aspire 5251-1513 Display Assembly Replacement
O que você precisa
  1. Acer Aspire 5251-1513 Display Assembly Replacement, Battery: passo 1, imagem 1 %32
    • Turn over the laptop so the back is facing up.
  2. Acer Aspire 5251-1513 Display Assembly Replacement: passo 2, imagem 1 %32 Acer Aspire 5251-1513 Display Assembly Replacement: passo 2, imagem 2 %32
    • Next to the battery is a switch with a lock symbol on it.
    • Unlock the switch by sliding it to reveal a red unlock symbol.
  3. Acer Aspire 5251-1513 Display Assembly Replacement: passo 3, imagem 1 %32 Acer Aspire 5251-1513 Display Assembly Replacement: passo 3, imagem 2 %32
    • Pull the other switch completely while the red unlock symbol is still present. The battery pack should pop up a bit.
  4. Acer Aspire 5251-1513 Display Assembly Replacement: passo 4, imagem 1 %32 Acer Aspire 5251-1513 Display Assembly Replacement: passo 4, imagem 2 %32
    • Remove the battery pack via the indentation at the top of the battery in between the two switches.
  5. Acer Aspire 5251-1513 Display Assembly Replacement, Display Assembly: passo 5, imagem 1 %32
    • Unscrew the 8.6 mm screws on the back panel with a Phillips #0 screwdriver.
  6. Acer Aspire 5251-1513 Display Assembly Replacement: passo 6, imagem 1 %32 Acer Aspire 5251-1513 Display Assembly Replacement: passo 6, imagem 2 %32
    • Using a plastic opening tool, lift up the panel and remove it completely.
  7. Acer Aspire 5251-1513 Display Assembly Replacement: passo 7, imagem 1 %32 Acer Aspire 5251-1513 Display Assembly Replacement: passo 7, imagem 2 %32
    • Flip the laptop over as shown.
    • Locate the six tabs keeping the keyboard in place.
  8. Acer Aspire 5251-1513 Display Assembly Replacement: passo 8, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Pull on the edge of the keyboard using a spudger or your hands.
    • As you pull on the keyboard, push the tabs in one by one using small tweezers.
  9. Acer Aspire 5251-1513 Display Assembly Replacement: passo 9, imagem 1 %32
    • Once you pop it out and its separated, slowly turn it over to reveal its attachment to the connector.
    • Do not pull the keyboard out too hard because you risk damaging both the connector and the laptop.
  10. Acer Aspire 5251-1513 Display Assembly Replacement: passo 10, imagem 1 %32
    • Using tweezers, slide the the tab down. This will release the connector that you can gently pull out of the socket.
    • If it does not come out easily, then you did not release it with the tabs and you risk ripping the connector.
  11. Acer Aspire 5251-1513 Display Assembly Replacement: passo 11, imagem 1 %32
    • Once freed, remove the keyboard entirely and put it aside.
  12. Acer Aspire 5251-1513 Display Assembly Replacement: passo 12, imagem 1 %32 Acer Aspire 5251-1513 Display Assembly Replacement: passo 12, imagem 2 %32
    • Flip the computer gently so that the back is facing you.
    • Remove all 12 of the 7.6 mm screws on the backside with a Phillips #0 screwdriver.
    • Remove 4 of the 5.4 mm screws on the backside with a Phillips #00 screwdriver.
  13. Acer Aspire 5251-1513 Display Assembly Replacement: passo 13, imagem 1 %32
    • Flip the computer back over.
    • Unscrew the seven 5.6 mm screws located on the top cover using a Phillips #0 screwdriver.
  14. Acer Aspire 5251-1513 Display Assembly Replacement: passo 14, imagem 1 %32
    • Locate the 4 connectors that must also be disconnected.
  15. Acer Aspire 5251-1513 Display Assembly Replacement: passo 15, imagem 1 %32
    • For the Power button cable and touchpad cable, please disconnect the connector using tweezers to pull down the brown tabs.
    • For the smaller right and left speaker cables, pull out the black tab completely also using tweezers.
  16. Acer Aspire 5251-1513 Display Assembly Replacement: passo 16, imagem 1 %32 Acer Aspire 5251-1513 Display Assembly Replacement: passo 16, imagem 2 %32
    • Using a plastic spudger or your hands, carefully lift up the corner of the top panel.
    • Continue to lift the panel until it is removed completely.
  17. Acer Aspire 5251-1513 Display Assembly Replacement: passo 17, imagem 1 %32
    • Locate the video cable connector keeping the screen connected to the motherboard.
  18. Acer Aspire 5251-1513 Display Assembly Replacement: passo 18, imagem 1 %32 Acer Aspire 5251-1513 Display Assembly Replacement: passo 18, imagem 2 %32
    • Unscrew the 8.6 mm bottom screws on the both hinges to separate the screen from the rest.
    • The computer is still connected to the backside of the motherboard so do not yank it off completely.
  19. Acer Aspire 5251-1513 Display Assembly Replacement: passo 19, imagem 1 %32
    • Remove the circle sticker and unscrew the 6.7 mm screws with a Phillips #0 screwdriver.
  20. Acer Aspire 5251-1513 Display Assembly Replacement: passo 20, imagem 1 %32
    • Peel back the screen carefully using a plastic spudger or your hands.
  21. Acer Aspire 5251-1513 Display Assembly Replacement: passo 21, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove all six 3.6mm screws on the sides of the screen.
  22. Acer Aspire 5251-1513 Display Assembly Replacement: passo 22, imagem 1 %32
    • Disconnect the webcam connector by gently pulling on the tabs using your hands or tweezers.
  23. Acer Aspire 5251-1513 Display Assembly Replacement: passo 23, imagem 1 %32 Acer Aspire 5251-1513 Display Assembly Replacement: passo 23, imagem 2 %32
    • Remove the screen completely.
Conclusão
Uma outra pessoa concluiu este guia.
Gicely Rodriguez
Membro desde: 02/14/19
1.029 Reputação
Autoria de 5 guias
Equipe
USF Tampa, Team S1-G6, Leahy Spring 2019 Membro de USF Tampa, Team S1-G6, Leahy Spring 2019
USFT-LEAHY-S19S1G6
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 19
Duração total: 693
